The Colibri T30 product group is end-of-life (EOL). For further details please check the revision history of the product and the related PCN. Customers using end-of-life (EOL) Tegra products are advised to use our migration guide to seamlessly migrate to recommended hardware and software solutions for their products.
For a direct replacement, Toradex recommends the Colibri iMX6, Colibri iMX8 product group or a transition to the Verdin product family.
하이라이트
Powered by NVIDIA: Tegra 3 Quad Core Processor
The Colibri T30 is a SODIMM sized computer module based on the NVIDIA© Tegra 3 embedded system-on-a-chip. The Cortex A9 quad core CPU peaks at 1.4 GHz. The module delivers very high CPU and graphic performance with minimum power consumption.
The Colibri T30 incorporates DVFS (Dynamic Voltage and Frequency Switching) and Thermal Throttling which enables the system to continuously adjust operation frequency and voltage in response to changes in workload and temperature to get the best performance with the lowest power.
The integrated NVIDIA Graphics enables visually rich, smooth and fast user interfaces.
Supreme Graphics Performance for Demanding Applications
The module targets a wide range of applications, including: Digital Signage, Medical Devices, Navigation, Industrial Automation, HMIs, Avionics, Entertainment System, POS, Data Acquisition, Thin Clients, Robotics, Gaming and much more
It offers a wide range of interfaces from simple GPIOs, industry standard I2C and SPI buses through to high speed USB 2.0 interfaces and a high speed memory bus. The HDMI interface makes it very easy to connect large, full HD resolution displays.
Easy Performance Upgrade
Existing customers will benefit from an extremely easy migration path from the current Colibri PXAxxx or Colibri T20 module range to the Colibri T30 – all Colibri modules are electrically pin compatible. New customers will also appreciate the ability to select the Colibri module most suitable for their application to achieve the optimum price/performance balance without the need to support different carrier board designs.
Latest Information on Colibri T30
운영 체제
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NVIDIA Tegra 3 processor based Colibri and Apalis T30 SoMs. This allows system designers to focus the application only instead of focusing on the OS and low-level device drivers. Other OS such as Android are supported by our partners.
Windows Embedded Compact 7 and 2013 are supported on both Colibri and Apalis T30. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
캐리어 보드
SBC와 캐리어 보드에 대해 자세히 알아보기액세서리
- No special drivers required
- Atmel touch driver
